LogicMachine - Modify Objects name
Good evening,
I've loaded a Logic Machine 5 with a large number of objects, some virtual, some standard, etc.
My question stems from another issue: the vast majority of these objects share two letters that are almost always repeated, specifically the following naming convention: "P1". (Image attached.)
My question is quite simple: I want to create a backup and load these objects into two other Logic Machines. The problem is that in the second and third Logic Machines, instead of "P1", I need to replace it with "P2" and "P3".
Is it possible to do this without having to go object by object? Is there a quick way to do it? Thank you very much.
Best regards,
Alejandro A.
You can use grp.create in script
https://kb.logicmachine.net/libraries/lu...eateconfig
just make sure to add forcename = true to grp.create config to overwrite name for an existing object
Run this script once:
db:query('UPDATE objects SET name=REPLACE(name, "P1", "P2")')
I understand what you're saying I should do, the problem is that would only change the name to P2. What I'm trying to do is change this:
BA_P1-4_A--CONSUMOS.Energia_Electrica
BA_P2-4_A--CONSUMOS.Energia_Electrica
upps, sorry, I didn't see last answer, thanks
