Threads: 47
Yesterday, 07:25
(This post was last modified: Yesterday, 12:30 by toujour.)
Hi, what is the better way to control a blind from the new Visu ?
When I use this control
I have a problem with the slats ( I think the bit stop doesn't work properly. I can't open and close slats by singol tap on the button.....the stop is always in the same direction).
Alberto
KNX Advanced Partner + Tutor
Threads: 30
This was designed for window/blind actuator. What is the difference for the shutters?
Threads: 47
Yesterday, 12:28
With the shutters the bit stop always works (0 or 1 value).
With the blinds the bit stop has a sense ( 0 --> open slats by one step , 1 --> close slats by one step ).
for example there are 10 steps to open/close the slats completely
The best think is with short and long command (is it possible ?...or I have to use javascript).
Otherwise...How can I change the value of the stop ?
Threads: 30
Why don't you use byte control instead?
