A problem has been observed with the consumption kWh graphs (trend logs).
The graphs are created in the SpaceLYnk environment, data is received via Modbus TCP (powertag link etc.).
Such readings as kW; Amps; Power Factor - all of them can be displayed graphically (day; week; month). BUT...
it is not possible to display the consumption kWh in a monthly basis (the reading appears only when the weekly view is selected).
Everything worked fine before.
This problem is also observed for another KNX group that I want to display (specifically kWh).
I would like to note that the objects are displayed with a real value that is currently...
Photo attached.
Where could the problem be?
Thank you
It also seems strange that January 2026 shows 59 day?!?.
December 2025 30 days (correct)
March 2026 30 days (correct)
Photo attached.
Thank you
