Yesterday, 01:29
(This post was last modified: Yesterday, 01:33 by savaskorkmaz.)
As you know, the combined light widget has a minimum width of 200 pixels. We are creating plan views for iPhone (we do not use the tile view), and the standard iPhone design resolution is 393 × 852 pixels.
We cannot use a higher custom resolution because non-standard design resolutions cause issues with schedules and other UI elements. With the current 200-pixel minimum width, it is not possible to place light widgets side by side on an iPhone screen (200 + 200 = 400 pixels, which exceeds 393 pixels, even before accounting for gaps).
Would it be possible to reduce the minimum width limit from 200 pixels to 175 pixels?
If the minimum width is reduced to 175 pixels, we would be able to place twice as many light widgets on the same page (for example, 16 widgets instead of 8).
Thanks in advance.
Thanks in advance.
