Trend logs kWh
A problem has been observed with the consumption kWh graphs (trend logs).
The graphs are created in the SpaceLYnk environment, data is received via Modbus TCP (powertag link etc.).
Such readings as kW; Amps; Power Factor - all of them can be displayed graphically (day; week; month). BUT...
it is not possible to display the consumption kWh in a monthly basis (the reading appears only when the weekly view is selected).
Everything worked fine before.
This problem is also observed for another KNX group that I want to display (specifically kWh).
I would like to note that the objects are displayed with a real value that is currently...
Photo attached.
Where could the problem be?
Thank you
It also seems strange that January 2026 shows 59 day?!?.
December 2025 30 days (correct)
March 2026 30 days (correct)
The second issue is clearly a bug. Regarding the missing data, did you SL reboot recently or so? Check alerts.
Nothing is showing in Alerts, everything is fine.
I'm also trying to add the group to Trend again, but the same thing happens.
I set it to post to Trend for 30 minutes, I'll see if anything changes.
I didn't reboot SL.
Maybe this information is useful to someone..
Since February has arrived, the problems with the graphical display of kWh by month have been resolved.
