Visu updates / changelog (20260128 - stable, 20260205 - beta)
Version 20260128 (stable)
Allow closing widget pop-up window by clicking outside of it
Add short/long option to movement widget (emulates KNX shutter actuator behavior)
Fix "no shape" icon display consistency between different widgets
Rework additional icon range matching logic:
- Value matching rules: Min ≤ Value ≤ Max or Value = Min if Max is not set
- Matching is be done in reverse order. If ranges overlap (previous max = next min) then the latter will be used
Custom JS:
- Add Visu active-plan-change event
- Add widget.listen(ga, cb) method
Widget wishlist: https://forum.logicmachine.net/showthread.php?tid=5875
Feature requests: https://forum.logicmachine.net/showthread.php?tid=5692
Bug reports: https://forum.logicmachine.net/showthread.php?tid=5892
Custom JS reference: https://kb.logicmachine.net/misc/visu/
Video tutorials: https://forum.logicmachine.net/showthread.php?tid=6238
Manuals: https://logicmachine.net/manuals/visu-20251120.pdf
Version 20260205 (beta)
Due to many changes this version is first published as a package and is not available in the app store.
Cloud Visu won't be updated until a new stable version is published.
Most notable changes:
- Fix for older browsers
- Plan "Show" option is ignored if View mode is either "Plan view only" or "Tile view only"
- Page zoom via touch pinch can be disabled in Global appearance settings
- Value select widget selection list can be configured to always open in a pop-up window
- Tile view Category widget can be duplicated (only the Category widget itself, without any child widgets)
- "Invert" option added to Switch widget
- Custom SVG icons can now be colorized by enabling "Apply color to custom SVG icons" in Global appearance settings
For this to work, SVG icon must be prepared accordingly:
1. Add id="root" to the <svg> element
2. Add fill="currentColor" to the <svg> element
3. Use viewBox for sizing, do not use width and height
SVG icons without these modifications won't be displayed.
Example icon attached.
.ipk   visu-20260205.ipk (Size: 784.71 KB / Downloads: 16)
.svg   key.svg (Size: 745 bytes / Downloads: 16)
