Threads: 52
26.01.2026, 07:25
(This post was last modified: 26.01.2026, 12:30 by toujour.)
Hi, what is the better way to control a blind from the new Visu ?
When I use this control
I have a problem with the slats ( I think the bit stop doesn't work properly. I can't open and close slats by singol tap on the button.....the stop is always in the same direction).
Alberto
KNX Advanced Partner + Tutor
Threads: 30
This was designed for window/blind actuator. What is the difference for the shutters?
Threads: 52
26.01.2026, 12:28
With the shutters the bit stop always works (0 or 1 value).
With the blinds the bit stop has a sense ( 0 --> open slats by one step , 1 --> close slats by one step ).
for example there are 10 steps to open/close the slats completely
The best think is with short and long command (is it possible ?...or I have to use javascript).
Otherwise...How can I change the value of the stop ?
Threads: 30
Why don't you use byte control instead?
Threads: 52
because it has one more tap for use ....and vertical slide is not good in plant (too big) because I have 4 motors for every windows
Threads: 52
one think.....I'm using the step control (it is good with long and short !!) but I have a problem.
I have the central stop button changes state by the Movement status
I think the change active state could be at the up/down button and not on the stop button (or their could change by the position status).
am I doing something wrong?
Alberto
Threads: 30
It shows what is the active state, if blinds move then the left/right is highlighted if stop then the middle.
Threads: 52
ok, but I don't see the final status of the blind....closed or opened ?
Threads: 30
It is not about blind status, it is about, is it moving or did it stop. There is position status object which can display position in %, use icon and value.
Threads: 52
is it possible insert an option that send the stop when I release the button ?
Threads: 48
Do you mean when short/long press option is enabled?
