20.07.2024, 17:35
Does anybody have a good reference/manual/white paper for learning how to create "custom widgets" ?
Creating a custom widget
20.07.2024, 17:35
22.07.2024, 08:29
See attached, we can share the widgets src if needed but any custom widget will be only visible locally not in cloud.
17.02.2026, 10:52
Hello everyone,
sorry if this has already been answered, but I could not find definitive info. I've read the attached document and I've got the following doubts: - Will this add a new custom widget I can use in the admin UI of the old visualization (scada) when creating pages ? - Where should I upload the files with the described structure ? Which ftp user should I use ? Thanks in advance for your help Antonio
17.02.2026, 10:55
This refers to Mosaic only. It is recomended to use new Visu for any new projects.
17.02.2026, 11:11
Thank you Daniel for your answer.
I didn't mention I'm actually using wiser for knx, and as such I think I'm not able to use the new Visu. Correct ?
17.02.2026, 12:32
Thanks, and is it possible to create a custom widget for the old visualization running on wiser ?
