It is very simple, just define coordinates and select or create new objects. Values can be updated instantly by pressing the Save and update weather button. The weather will be updated once every hour. Objects are updated on change of value.
How often info renew from the weather portal? May be for next app version is possible to add group from/to for automatic assigning weather info for new projects for faster integration? And finally we need weather widget for new visu!
Hi Daniel,
good work as always, do you think it is possible have a string object with the condictions? For example Sunny, cloudy, rain or other
Best regards Cristian Grassi
