Alert manager ipk
Good morning Dev,
Could be possible have the ipk file for app in object? I have a client without internet connection.
Could be interesting open a section with all this file. Now a day happens often LM not connected to web.
Best regards Cristian
https://forum.logicmachine.net/showthrea...3#pid22783
Hello Dears,
I want to use the app acknowledge to trigger a GA, to be used for a KNX Touch screen acknowledgement
Best Regards,
This is not possible in Alert app.
Only possible when the app is embedded via iframe into your visu, here is a sample custom JS that makes some interaction possible:
$(function() {
    // Remote Press Acknowledge Button
    $(document).ready(function() {
        var f = $('iframe');
        f.load(function() {
                grp.listen('0/3/0', function(object, state) {
                    if (state == 'value' && object.value == true) {
                        f.contents().find('#AcknowledgeButton').click();
                }, true);
    // Remote Press Mute Button
        f.load(function() {
                grp.listen('0/3/1', function(object, state) {
                        f.contents().find('#MuteButton').click();
                }, true);
    // Write to object when Acknowledge is pressed by a user
        f.load(function() {
            f.contents().find('#AcknowledgeButton').click(function() {
                grp.write('0/2/0', false)
    // Write to object when Mute is pressed by a user
        f.load(function() {
            f.contents().find('#MuteButton').click(function() {
                grp.write('0/2/0', true)
    // Hide Acknowledge Button
        f.load(function() {
            f.contents().find('#AcknowledgeButton').hide();
    // Hide Mute Button
        f.load(function() {
            f.contents().find('#MuteButton').hide();
