Remote connection via http server
If I open a port through the router, could I connect to a logic machine via the WAN IP address?
 Puerto Externo = WAN port
Puerto Interno = LAN port
To webserver yes, to KNX and BACnet no.
What I want is to access the SCADA system, that is, the logic machine, through its static IP address. The problem I've encountered is that the network card I installed in the router doesn't have a static IP address, so the HTTP or HTTPS option won't work.
I'm looking at the VPN option as a zero-tier solution.
I don't understand the state "REQUESTING_CONFIGURATION"
Have you configured a valid gateway and DNS in Network > Interfaces > eth0?
Here you can see
Your gateway IP is in another subnet, this setup won't work.
Either the gateway is wrong and should be 192.168.0.1 or LM IP must be in the 192.168.1.x range.
You are right, my device's gateway was my router's ip, now i see my LM in zerotier
