I have rebooted the LM multiple times and tested other settings, but without success.
- I tested a USB programming interface and then it works right away.
- I cannot program other KNX devices either.
- I also have another LM located in a different part of the building, with its own KNX installation. It doesn't work there either. Both installations are behind a Mikrotik router. Could that have something to do with it?
Mail from Rithum: Each Rithum Switch uses one TP connection to an IP Gateway, in this case your LogicMachine. This connection is persistent.
Most KNX gateways publish the number of concurrent connections they can support, but I can't see that published anywhere for the LogicMachine. ETS uses the same mechanism, so if your gateway only supports one connection, that is what the issue is.
The Weinzierl 732, for example, supports up to 8 connections.
How many connections are supported by the LogicMachine?
(17.03.2026, 13:41)gjniewenhuijse Wrote: Mail from Rithum: Each Rithum Switch uses one TP connection to an IP Gateway, in this case your LogicMachine. This connection is persistent.
does your device support KNX Rouring?
I made some test about 10 yaers ago, 8 tunnelibg connections worked without problem
We don't really specify the number supported of tunneling connections as it all depends of device load(LM doas much more then just KNX) but myself I used 6 at the same time in the past.
