Feature requests
First of all, congratulations on the work done on the new display, both on smartphones and PCs.
I wanted to ask a question: previously it was possible to force the display format (PC or smartphone) using the URL. In this new version, is there or is there a plan to manually select the desired display format?
It would be very useful to be able to choose it regardless of the device.
Thank you.
It will be possible to do by adding ?mode=plan or ?mode=tile to the Visu app URL in the next beta version.
Borders on values in Plan view
Prefix (like suffix but before the value)
It can be done via Custom CSS.
Value border (additional class value-border):
.value-border .value {
  border: 1px red solid;
  border-radius: 4px;
  padding: 2px 4px;
  background: yellow;
Value prefix (additional class value-prefix):
.value-prefix .value-content:before {
  content: "Prefix ";
(30.03.2026, 07:47)admin Wrote: It can be done via Custom CSS.
  border-radius: 4px;
  padding: 2px 4px;
  background: yellow;
  content: "Prefix ";
Thank you, it works but i sometimes like for visibility purposes to add also a border in the plan view to not only values but also icons so a selection box would be a great addition
Prefix works also but for every individual prefix you have to make a CSS. Having a box like suffix that you can fill with a prefix would be even better.
Quote:Thank you, it works but i sometimes like for visibility purposes to add also a border in the plan view to not only values but also icons so a selection box would be a great addition
Enable "Apply background/border to Plan view widgets (excluding widgets in Compact mode)" in Global appearance settings > Widgets
Point is i would like to have it also for widgets in compact mode specially for disabled people that can only view in greyscale.
There are too many customization options already Smile
Some very specific cases like yours can be solved with custom CSS.
Would it be possible to add a PIN to open widgets?
[Image: H6M5RS5.png]
