SD Card lifetime
I have a reactor that has slowed down significantly. It's been running for about 4 years. Is it a good idea to change the SD card every now and then? If so, how do I take a card image? Do you have pre-made card images?
Thank you very much.
The system runs in RAM so SD card should not slow LM only fully brake it. It is up to you, the latest cards are much better and we see very little issues with them. Still the SD is probably the weakest link. The full image is done the same way as with recovery
https://kb.logicmachine.net/misc/reflash...ng-player/
Instead of restore you do backup.
