string value display
hi,
How can I display a formatted string expression?
there is Only "Numeric value display". Bu i need "string value display". (250 byte string)
Use Text input widget in read-only mode.
Is it possible change the color of the text (read only option) from the value of an other boolean object ?
KNX Advanced Partner + Tutor
You can do it same like this example.
https://forum.logicmachine.net/showthrea...2#pid40642
You don't need any scripts. Simply use Switch widget in read-only mode. Set Display mode to "Value", Shape to "No shape". Adjust On/Off state text and color as needed.
(20.04.2026, 08:33)admin Wrote: You don't need any scripts. Simply use Switch widget in read-only mode. Set Display mode to "Value", Shape to "No shape". Adjust On/Off state text and color as needed.
Uhm....now I try (I have the main object from a 250byte string.....so the text change from the event)
Then you need to use Custom JS. Change widget ID (46), listening address (0/0/1) and colors as needed.
Note that you need to switch to the User view for Custom JS to work.
Visu.on('widget-ready', 46, ({ widget }) => {   const el = widget.getCompactModeEl()   widget.listen('0/0/1', (value) => {     el.style.color = value ? '#FF9900' : '#0099FF'   }) })
