BACNET IP and IP filters comm
#61
For Filter to work you must select correct filtering policy,  If the selected objects you want to block then select 'drop selected'
So, if, for example, I have 200 group addresses common to LM_1 and LM_4, and I only want communication between 5 of those 200 group addresses, the best thing I can do is:
- LM_1 > LM_4 ->> in LM_1 KNX connection >> IP > local > DST group policy >> Drop..... >> Group address list >> enter the 150 group addresses >> OK
- LM_4 > LM_1 ->> in LM_4 KNX connection >> IP > local > DST group policy >> Drop..... >> Group address list >> enter the 150 group addresses >> OK
Could this be a solution to allow communication only between 5 group addresses stored in LM_1 and LM_4?
Other way around, you select accept selected and add this 5 groups.
Could you clarify that last point for me?
Everything's clear now.
