21.05.2026, 16:16
Good afternoon,
I'd like to ask a question, if possible.
I have an alert manager screen on a logic machine, and it needs to display all the alarms from that logic machine and three others.
Initially, I thought about creating standard group addresses using an ETS file, so that the LM_1 alarm addresses would be sent to the LM with the alert manager via IP.
The problem is that these addresses are empty; they have no data. What I'm observing is that the ETS group monitor is generating repetitions on the KNX bus, and I don't want those signals going to the KNX bus.
Is there any way to prevent these GAs from generating repetitions on the KNX bus, or is there a way for the virtual objects created on each LM to send data from one LM to another?
I don't know how to prevent the repetitions, and they are all happening in physical GAs that are empty in the ETS file, without any communication objects from KNX devices. Thank you so much
