button confirm
Hello, is it possible to validate an action like this with a button?
<script>
if (confirm("Do you want to continue?")) {
document.write("yes")
} else {
document.write("no")
</script>
Thank you
What task do you have exactly?
(Yesterday, 13:07)admin Wrote: What task do you have exactly?
ask for confirmation of the operation I am going to do if I answer yes
Ok, but what action do you want to perform? Change group address, show a different plan or open some link? Is it something that can already be done using an existing widget (which?) or do you need something fully custom?
(10 hours ago)admin Wrote: Ok, but what action do you want to perform? Change group address, show a different plan or open some link? Is it something that can already be done using an existing widget (which?) or do you need something fully custom?
Simply, from a virtual button with a script, I'd like an alert that authorizes its execution.
For example, if you leave the house, it responds, "Are you sure?" Yes, I execute the command; no, I cancel the command.
A out of the box option(no the same) is PIN protection.
