9 hours ago
Hey everyone,
Just looking for a general sanity check here. I'm trying to figure out if multicast is being allowed or blocked on a client's network.
My test setup:
What works:
The issue:
Based on these findings, it seems to me that standard unicast traffic (like pings) is fine, but multicast traffic is being blocked by the network switches. Is that a correct assumption?
And if so, what is the best way for me to test and prove this from my side? I want to gather as much concrete evidence as possible before I approach their IT department so they actually understand the issue and don't just brush it off.
Appreciate any advice or troubleshooting tips!
My test setup:
- Logic Machine (LM): 192.168.5.10 (KNX physical address 1.1.1)
- KNX IP Router: 192.168.5.11 (KNX physical address 1.2.0)
- Multicast Address: 224.0.23.12
- Filter Tables: Everything is explicitly set to "Route" on all devices.
What works:
- I can successfully ping the IP Router (192.168.5.11) from the Logic Machine.
- When connected to the LM (192.168.5.10) via ETS, I can see and control everything on line 1.1.X, and the LM UI updates perfectly.
The issue:
- If I connect to the IP Router (192.168.5.11) via ETS, I can only see and control things on line 1.2.X. Crucially, these telegrams are not updating or crossing over to the LM on 1.1.X
