Zigbee USB dongle connected again
for some tests I connected back to LM USB Zigbee stick E18-2G4U04B to LM USB port. Zigbee config I switched to USB. But not working, at used ports USB stick not seen. Do I need to do some usb port setting/reinitialization? Previously modem was connected to USB port. Will it work with latest FW of LM? Actively stick was used ~ 4 years ago. Can I also use USB HUB?
Init script:
os.execute('echo 1 > /sys/bus/platform/devices/ci_hdrc.0/force_full_speed')
os.execute('echo 1 > /sys/bus/platform/devices/ci_hdrc.1/force_full_speed')
os.execute('usbreset /dev/bus/usb/001/001')
Alex
Post what you have in System config > Status > System log when the dongle is connected to LM.
Hi, restarted LM. Log:
Jul 3 12:13:23 Home daemon.info avahi-daemon[1236]: Service "Web Server on Home" (/etc/avahi/services/http.service) successfully established.
Jul 3 12:13:23 Home daemon.info avahi-daemon[1236]: Service "Home" (/etc/avahi/services/lm.service) successfully established.
Jul 3 12:13:22 Home daemon.info avahi-daemon[1236]: Server startup complete. Host name is Home.local. Local service cookie is 1131558326.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Registering HINFO record with values 'ARMV7L'/'LINUX'.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Registering new address record for 192.168.45.156 on eth0.IPv4.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Network interface enumeration completed.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: New relevant interface eth0.IPv4 for mDNS.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.45.156.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Loading service file /etc/avahi/services/lm.service.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Loading service file /etc/avahi/services/http.service.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: avahi-daemon 0.8 starting up.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Successfully dropped root privileges.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Found user 'nobody' (UID 65534) and group 'nogroup' (GID 65534).
Jul 3 12:13:15 Home kern.info kernel: [ 10.995488] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
Jul 3 12:13:10 Home user.info sysinit: /lib/genohm-scada/storage/db/current.db: OK
Jul 3 12:13:09 Home kern.info kernel: [ 5.159419] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Jul 3 12:13:08 Home kern.info kernel: [ 3.276218] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc
Jul 3 12:13:07 Home user.info sysinit: /dev/mmcblk0p3: clean, 3289/38400 files, 35144/153600 blocks
Jul 3 12:13:07 Home user.info sysinit: e2fsck 1.47.2 (1-Jan-2025)
Jul 3 12:13:07 Home kern.info kernel: [ 3.123267] SMSC LAN8710/LAN8720 2188000.ethernet-1:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-1:00, irq=POLL)
Jul 3 12:13:06 Home kern.info kernel: [ 1.983184] SMSC LAN8710/LAN8720 2188000.ethernet-1:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-1:00, irq=POLL)
Jul 3 12:13:06 Home kern.info kernel: [ 1.652440] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Jul 3 12:13:06 Home kern.info kernel: [ 1.649664] usb 1-1.1: SerialNumber: __0X00124B0014DBCDAB
Jul 3 12:13:06 Home kern.info kernel: [ 1.649653] usb 1-1.1: Manufacturer: Texas Instruments
Jul 3 12:13:06 Home kern.info kernel: [ 1.649640] usb 1-1.1: Product: TI CC2531 USB CDC
Jul 3 12:13:06 Home kern.info kernel: [ 1.649627] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 3 12:13:06 Home kern.info kernel: [ 1.649583] usb 1-1.1: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
Jul 3 12:13:06 Home kern.info kernel: [ 1.535165] usb 1-1.1: new full-speed USB device number 3 using ci_hdrc
Jul 3 12:13:06 Home kern.info kernel: [ 1.458112] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc
Jul 3 12:13:06 Home kern.info kernel: [ 1.248553] hub 1-1:1.0: 7 ports detected
Jul 3 12:13:06 Home kern.info kernel: [ 1.248329] hub 1-1:1.0: USB hub found
Jul 3 12:13:06 Home kern.info kernel: [ 1.247579] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jul 3 12:13:06 Home kern.info kernel: [ 1.247550] usb 1-1: New USB device found, idVendor=0424, idProduct=2507, bcdDevice= 0.00
Jul 3 12:13:06 Home kern.info kernel: [ 1.091261] usb 1-1: new high-speed USB device number 2 using ci_hdrc
Jul 3 12:13:06 Home kern.debug kernel: [ 0.895195] TERM=linux
Jul 3 12:13:06 Home kern.debug kernel: [ 0.895190] HOME=/
Jul 3 12:13:06 Home kern.debug kernel: [ 0.895184] with environment:
Jul 3 12:13:06 Home kern.debug kernel: [ 0.895181] /etc/preinit
Jul 3 12:13:06 Home kern.debug kernel: [ 0.895175] with arguments:
Jul 3 12:13:06 Home kern.info kernel: [ 0.895164] Run /etc/preinit as init process
Jul 3 12:13:06 Home kern.info kernel: [ 0.891199] Freeing unused kernel memory: 1024K
Jul 3 12:13:06 Home kern.info kernel: [ 0.889900] VFS: Mounted root (ext3 filesystem) on device 179:2.
Jul 3 12:13:06 Home kern.warn kernel: [ 0.889827] ext3 filesystem being mounted at /root supports timestamps until 2038-01-19 (0x7fffffff)
Jul 3 12:13:06 Home kern.info kernel: [ 0.889763] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jul 3 12:13:06 Home kern.info kernel: [ 0.862804] mmcblk0: p1 p2 p3
Jul 3 12:13:06 Home kern.info kernel: [ 0.861520] mmcblk0: mmc0:1234 SA32G 28.8 GiB
Jul 3 12:13:06 Home kern.info kernel: [ 0.860443] mmc0: new high speed SDHC card at address 1234
Jul 3 12:13:06 Home kern.warn kernel: [ 0.858348] mmc0: host does not support reading read-only switch, assuming write-enable
Jul 3 12:13:06 Home kern.info kernel: [ 0.858064] Waiting for root device /dev/mmcblk0p2...
Alex
Enable debug logging in the ZigBee app configuration and post what you have in the ZigBee app logs.
Finally USB Zigbee started after 3rd reboot, may be USB Hub not seen previously
Alex
