10 hours ago
Hello.
Device: LM5P2-KCDZ
Issue: zigbee functionality lost after power reset.
Zigbee debug logging enabled, but log is empty.
Indicator in zigbee app web interface blinks with red.
Status led on zigbee PCB under LM5 cover is steady red.
Here is the system log:
Any advises please?
Device: LM5P2-KCDZ
Jul 6 08:48:06 LogicMachine daemon.info avahi-daemon[1111]: Service "Web Server on LogicMachine" (/etc/avahi/services/http.service) successfully established.
Jul 6 08:48:06 LogicMachine daemon.info avahi-daemon[1111]: Service "LogicMachine" (/etc/avahi/services/lm.service) successfully established.
Jul 6 08:48:05 LogicMachine daemon.info avahi-daemon[1111]: Server startup complete. Host name is LogicMachine.local. Local service cookie is 4284172590.
Jul 6 08:48:04 LogicMachine daemon.info avahi-daemon[1111]: Registering HINFO record with values 'ARMV7L'/'LINUX'.
Jul 6 08:48:04 LogicMachine daemon.info avahi-daemon[1111]: Registering new address record for 192.168.1.125 on eth0.IPv4.
Jul 6 08:48:04 LogicMachine daemon.info avahi-daemon[1111]: Network interface enumeration completed.
Jul 6 08:48:04 LogicMachine daemon.info avahi-daemon[1111]: New relevant interface eth0.IPv4 for mDNS.
Jul 6 08:48:04 LogicMachine daemon.info avahi-daemon[1111]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.125.
Jul 6 08:48:04 LogicMachine daemon.info avahi-daemon[1111]: Loading service file /etc/avahi/services/lm.service.
Jul 6 08:48:04 LogicMachine daemon.info avahi-daemon[1111]: Loading service file /etc/avahi/services/http.service.
Jul 6 08:48:04 LogicMachine daemon.warn avahi-daemon[1111]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Jul 6 08:48:04 LogicMachine daemon.info avahi-daemon[1111]: avahi-daemon 0.8 starting up.
Jul 6 08:48:04 LogicMachine daemon.info avahi-daemon[1111]: Successfully dropped root privileges.
Jul 6 08:48:04 LogicMachine daemon.info avahi-daemon[1111]: Found user 'nobody' (UID 65534) and group 'nogroup' (GID 65534).
Jul 6 08:48:03 LogicMachine kern.info kernel: [ 9.870812] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
Jul 6 08:48:00 LogicMachine user.info sysinit: /lib/genohm-scada/storage/db/current.db: OK
Jul 6 08:47:58 LogicMachine kern.info kernel: [ 5.193579] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Jul 6 08:47:57 LogicMachine kern.info kernel: [ 3.750690] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc
Jul 6 08:47:57 LogicMachine user.info sysinit: /dev/mmcblk0p3: clean, 930/468640 files, 68314/1873920 blocks
Jul 6 08:47:57 LogicMachine user.info sysinit: Setting free blocks count to 1805606 (was 1805608)
Jul 6 08:47:57 LogicMachine user.info sysinit: /dev/mmcblk0p3: recovering journal
Jul 6 08:47:56 LogicMachine user.info sysinit: e2fsck 1.47.0 (5-Feb-2023)
Jul 6 08:47:56 LogicMachine kern.info kernel: [ 3.161329] SMSC LAN8710/LAN8720 2188000.ethernet-1:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-1:00, irq=POLL)
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 2.041422] SMSC LAN8710/LAN8720 2188000.ethernet-1:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-1:00, irq=POLL)
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 1.534943] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc
Jul 6 08:47:55 LogicMachine kern.debug kernel: [ 1.067023] TERM=linux
Jul 6 08:47:55 LogicMachine kern.debug kernel: [ 1.067018] HOME=/
Jul 6 08:47:55 LogicMachine kern.debug kernel: [ 1.067014] with environment:
Jul 6 08:47:55 LogicMachine kern.debug kernel: [ 1.067010] /etc/preinit
Jul 6 08:47:55 LogicMachine kern.debug kernel: [ 1.067005] with arguments:
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 1.066996] Run /etc/preinit as init process
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 1.066878] Freeing unused kernel memory: 1024K
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 1.065694] VFS: Mounted root (ext3 filesystem) on device 179:2.
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 1.065594] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 1.061832] EXT4-fs (mmcblk0p2): recovery complete
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.869455] mmcblk0: p1 p2 p3
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.867984] mmcblk0: mmc0:aaaa WD08G 7.40 GiB
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.866896] mmc0: new high speed SDHC card at address aaaa
Jul 6 08:47:55 LogicMachine kern.warn kernel: [ 0.863479] mmc0: host does not support reading read-only switch, assuming write-enable
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.856293] Waiting for root device /dev/mmcblk0p2...
Jul 6 08:47:55 LogicMachine kern.err kernel: [ 0.856220] Warning: unable to open an initial console.
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.854425] hub 2-0:1.0: 1 port detected
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.854353] hub 2-0:1.0: USB hub found
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.853495] usb usb2: SerialNumber: ci_hdrc.1
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.853483] usb usb2: Manufacturer: Linux 5.10.215 ehci_hcd
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.853470] usb usb2: Product: EHCI Host Controller
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.853458] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.853439] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.853221] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
Jul 6 08:47:55 LogicMachine kern.info kernel: [ 0.840028] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2Any advises please?
