Wireguard problems
We have a frequent problem with wireguard seizing from time to time. Every time this happens, local network is working and fault can be solved by pressing only the OK button in wireguard configuration. Usually it is one random site at a time, however once it happened on all our sites simultaneously. We have every site connected through a reverse proxy directly to LM-s WG address and same fault does not occur on other devices connected through same WG server.
Version: 20251204
Is this a known issue or is there a known solution for this?
Do you have "Keep-alive interval" enabled? You can create a script that periodically sends ping or a HTTP request via WG interface and see if it helps.
Keepalive is 5 sec and has been. It has not helped. We have many devices with WG but LM is only one with this kind of problem. It would help if the WG watchdog and automatic refresh would be possible to do with skript but have not found such info from wiki.
You can create a scheduled script that tries to connect to a known IP/port over WG.
WG service is restarted if the connection cannot be established.
require('socket') sock = socket.tcp() sock:settimeout(5) res, err = sock:connect('192.168.1.1', 443) sock:close() if not res then   log('wg error', err)   os.execute('/etc/init.d/wireguard-lm restart') end
