Philips Hue App
I'm sharing an app for Philips hue. I tested it on my own installation with a Hue v2.
I don't have many Zigbee lights and main reason was to integrate 2 ZGP devices.
Current package: philips-hue_0.3.52_all.ipk
Features
  • Push-link pairing with a local Hue Bridge
  • Local mDNS bridge discovery, with manual IP entry fallback
  • Classic-first hybrid mode, classic-only mode, and API v2 mode
  • Discovery and sync for lights, groups/rooms/zones, scenes, and control devices/sensors
  • LM object creation from the app UI
  • Separate command and status group addresses
  • Button transformations for KNX writes: toggle, on, off, fixed value
  • Optional API v2 eventstream support, with classic fallback for button handling when needed
Install
  1. Install the .ipk from Apps
  2. Open the Hue app
  3. Use Discover Bridge or enter the bridge IP manually
  4. Press the bridge button and click Pair Bridge
  5. Refresh and create the LM objects you want
Notes
  • Default mode is hybrid and is the safest starting point
  • API v2 eventstream support is included, but in my setup it is not fully reliable yet and can create heavier system load, so hybrid/classic operation is currently the safer choice
  • Tested on my own live Hue + LogicMachine setup
  • License: MIT
Happy to hear feedback if anyone tests it on other Hue bridge/device combinations.
.ipk   philips-hue_0.3.52_all.ipk (Size: 1.04 MB / Downloads: 21)
0.3.52 → 0.4.1
  • Added Hue API v2 eventstream with immediate button actions, deduplication and stale-connection recovery.
  • Added KNX relative dimming, RGB, Kelvin, bridge profiles, connectivity overrides.
  • Added Bridge Pro MotionAware, grouped sensors, automations, effects and dynamic scenes.
  • MotionAware now exposes one generic presence object.
.ipk   philips-hue_0.4.1_all.ipk (Size: 101.23 KB / Downloads: 0)
