Hi, I've made a small app that lets you set a schedule for the luminaire temperature throughout the day. You can select a schedule for a specific region and season on the heat map, and then adjust it manually. Points are set for each hour, and the value is written to the group address of color temperature every minute. Values between the set points are linearly interpolated. Customize the luminaire temperature schedule to your own rhythm of life. Let the light adapt to you, not the other way around.
