Threads: 2
Hi!
Is there a way to enable KNX IP routing traffic through zerotier to connect remote locations together?
Threads: 35
You can do it via our cloud. Add two LMs to the same network by using same string(you will need to manually accept second LM) then tag objects which you want to pass trough lmcloud on both devices and then they will work in sync.
Threads: 48
All objects with lmcloud tag are exported to cloud. You can use this to exchange values between several LMs through our cloud.
Threads: 35
Yes, nothing was changed, all LMs must be on same cloud network for this to work.
