02.05.2017, 05:11
(This post was last modified: 02.05.2017, 05:12 by Anton Voskresenskiy.)
Have got another problem...
When I add a custom widget with images, its content is stored with a very strange path:
/apps/data/mosaic20/widgets/u/2/images/walllamp.png
Where /u/2/ corresponds to user defined widget number TWO !!! "Number TWO" means that this widget was added second to number ONE...
So.. to access images inside widgets you have to decide beforehand load sequence and put the correspondent link inside script.js If you change the sequence of widget loading to the system - all images will be broken
Why not to use /u/myname/ where "myname" is the name of a custom widget, that is not dependent on the load sequence?
Has anyone used custom widgets with images yet? Is there work around ? May be adding images to custom theme will solve the problem? Any ideas?
A.
A.
