Tell me where you can download the package "genohm-scada-reactorv3"
I don't think there is a package like that as it's default included in the FW...
If you need it for any reason, i would reinstall FW...
In "LogicMachine5 Reactor IO" there are no settings for binary inputs / outputs in the firmware and in the settings / packages there is no "genohm-scada-reactorv3" package, how to find or add a bookmark for the I / O settings
with respect.
(02.07.2017, 19:17)uxonet83 Wrote: In "LogicMachine5 Reactor IO" there are no settings for binary inputs / outputs in the firmware and in the settings / packages there is no "genohm-scada-reactorv3" package, how to find or add a bookmark for the I / O settings
with respect.
genohm-scada-reactorv3 - is a package for LM Re:actor V3, not for LM5
go to this page http://openrb.com/firmwares/
and use link LogicMachine5 Reactor IO if you have IMX 28 CPU
or this link LogicMachine5 Power / LogicMachine5 Reactor IO Power if your CPU is IMX6
Make sure, that upgrade is success (your firmware should be 20170620 or near)
if it is not and you still have FW 20170106, you should use script in attach first
.txt   upgrade from 20170106 script.txt (Size: 1.54 KB / Downloads: 21)
