LM5Lp not recieving Telegrams
I have a LogicMachine 5 Lite Power, that sends telegrams to the KNX bus, but does not recieve anything from the bus,
the LM is TP-UART, address corresponding to KNX Line, and there is no active filter policy.
With the ETS connected to the KNX bus, we send a read telegram to the bus, the response telegram is registered in the ETS Group Monitor, but there is no update in LM.
We tested the LM in a bench and works fine, sends and recieves KNX telegrams.
Any ideas?
(19.07.2017, 11:29)Morpheus09 Wrote: Hi,
Any ideas?
Hi!
maybe "auto update" button in object tab is disabled?
Sometimes even if "auto update" is enabled, objects in Objects tab are not updating, even if its receives them. Try to make an event script on some object or make a visualization with it so you can see if LM actually receives telegrams
Check in browser console, maybe there is some error.
