21.07.2017, 13:47
LogicMachine5 Reactor IO v2 is all-in-one cross-standard controller uniting in one device gateway functionality, cloud service integration, complex network logic engine, easy-to create visualization platform, IP Router, I/Os and much more.
v2 differs from initial v1 with possibility to use inputs for pulse metering, plus V2 has 2 analog outputs and 1-wire on board
Hightlights:![[Image: LM5-RIOE2-300x263.png]](http://openrb.com/wp-content/uploads/2017/07/LM5-RIOE2-300x263.png)
See here i.MX28 (CPU of LM2, LM3, LM4) and i.MX6 (optional 3x speed CPU for LM5 series devices) comparison tests: http://openrb.com/imx28-vs-imx6-cpu-test...icmachine/
Here is more information on LM5 Reactor IO v2: http://openrb.com/logicmachine5-reactor-io-v2/
LM comparison table: http://openrb.com/wp-content/uploads/201...17_web.pdf
Hightlights:
- 18 I/O ports
- LM5 Reactor IO v2 has built-in KNX TP1, EnOcean bi-directional interface (optional), two serial interfaces
Power-over-Ethernet powering - Application development and application store
- Cloud ready device with Microsoft Azure, Amazon Web Services and other services supported
- Gateway and uniform way of control of KNX, ModBus RTU/TCP, BACnet IP, EnOcean (optional), DMX, M-Bus, GSM and more
- Unlimited scenario and logic engine
- Unlimited visualization platform for PC and for touch devices
- Size: 6 DIN units
- Remote KNX bus control and KNX device reprogramming
- Object logging with trends support and data exporting to external servers
- Optional 3x more powerful CPU than all previous LogicMachine versions
