20.10.2015, 11:45
How to use scenes with the dali interface?
Is there a kind of "software scene" object?
Dali interface scenes
20.10.2015, 11:45
21.10.2015, 13:26
You can create simple scenes by making a script that writes the required values one by one.
11.11.2015, 15:34
12.11.2015, 07:31
Short example which can be used for any kind of scenes, not only for DALI.
First, you have to define each scene via a Lua table where each item is a table with two items: group address and value. Each scene has a unique id which can be a number or a string. callscene(id) sets all objects in given scene to their specified value. First it looks for a saved scene in storage and uses default values if storage is empty. savescene(id) gets current values of all objects from given scene and saves the whole scene in storage. Code: scenes = {}
scenes[1] = {
{ '15/1/1', 50 },
{ '15/1/2', 75 },
{ '15/1/3', 90 },
function callscene(id)
local key, scene
key = 'scene_' .. id
scene = storage.get(key, scenes[ id ])
if type(scene) ~= 'table' then
alert('Scene ' .. id .. ' not found')
return
for _, item in ipairs(scene) do
grp.write(item[ 1 ], item[ 2 ])
function savescene(id)
local key, scene
scene = scenes[ id ]
return
for i, item in ipairs(scene) do
scene[ i ][ 2 ] = grp.getvalue(item[ 1 ])
storage.set(key, scene)
12.11.2015, 09:17
many thanks
