Syslog and SNMP
Is it possible to export alerts, logs or object logs in syslog ?
Is there a way to monitor the logicmachine in SNMP (standard or private MIBs)?
Matthieu
Do you mean to external syslog on the network? It has a fairly simple UDP-based protocol which can be implemented via a script.
For SNMP we can provide LuaSNMP library, but our clients have only used it to query other devices, not other way round.
http://luasnmp.luaforge.net/index.html
(25.11.2015, 07:58)admin Wrote: Do you mean to external syslog on the network? It has a fairly simple UDP-based protocol which can be implemented via a script.
My idea was just to monitor the system (cpu, memory, disk, ...) with a monitoring tool like a standard linux device.
Just the standard MIB2 would be enough.
For the syslog, is there a way to make a code executer on each call of alert() ?
Matt
You can override alert function in user function library, then all scripts will use new function instead of old. You just have to implement syslogsend.
oldalert = alert
alert = function(text, ...)
 text = tostring(text) or ''
 text = string.format(text, ...)
 syslogsend(text)
 oldalert(text)
