Z-wave link parameter from advanced tab to object
Is it possible to link an object to a Z-wave value under the Advanced tab?
I have a Heatit z-wave thermostat configured as a power requlator.
The power can be adjusted between 0 and 100% (0-10) with the P parameter under the Advanced tab, in the Z-wave app.
How can i link this to an object?
Bump bump..
I really need to read and edit the P parameter (Power regulator setting 0-100%) from the visualization.
Is it possible to get access to the Z-wave node config parameters (under the advanced tab) via the visualization?
(29.11.2017, 18:49)oveh Wrote: Bump bump..
It is possible via script but you need quite a lot of information to query the data.
 cmd = 14,  - this is fixed
 node_id = 4,  - Device ID in the app
 value_id = 77333942,  - This one is not available today. It is hard coded in to DB. We just added to our list of improvements to display this info in the app.
 instance = 1, - this you have to read from device profile.
Once next version will be released please ask again I will send you the script.
When do you expect the new version will be released?
