Logic Machine objects to file for ETS Import
Hi all,
Is there any already made script to export LM objects in CSV or XML format for ETS import?
Thank you in advance
George
Try this (:
Thank you Erwin...
As always fast and right to the point!
(04.12.2017, 11:47)Erwin van der Zwart Wrote: Hi,
Try this (:
 Thank you so much it is just what i am looking for.....But it always show me the next error:
Resident script:52: attempt to concatenate field 'name' (a nil value)
stack traceback:
What am i doing wrong?
Kind Regars,
Probably you have some objects without name. You can delete them by mass delete - Delete unnamed objects.
(24.07.2019, 14:08)Daniel. Wrote: Probably you have some objects without name. You can delete them by mass delete - Delete unnamed objects.
Thanks for your help.
As you told me it was the reason.... i deleted the blank objects and now it didn't show the error but i never receive the email. I have receveid an "we have blocked a connection" from gmail and after that i activated the "no secure connection allowed"  in security page in gmail....but nothing.... i never received the csv file.
I tried with several gmail accounts and the same problem.
Any idea about it?
You can use this script. It will save csv in to ftp main folder
-- Get all objects from DB objects_table = db:getall('SELECT * FROM objects ORDER BY address ASC') log(objects_table) buffer = {} mainvalue = -1 middlevalue = -1 subvalue = -1 -- Loop through objects_table for _, object in ipairs(objects_table) do   address = knxlib.decodega(object.address)   addresstable = string.split(address, '/')   if mainvalue ~= addresstable[1] then      mainvalue = addresstable[1]        table.insert(buffer, '"Main Group ' .. addresstable[1] .. '","","","' .. addresstable[1] .. '/-/-"')   end   if middlevalue ~= addresstable[2] then      middlevalue = addresstable[2]      table.insert(buffer, '"","Middle Group ' .. addresstable[2] .. '","","' .. addresstable[1] .. '/' .. addresstable[2] .. '/-"')   end   if subvalue ~= addresstable[3] then      subvalue = addresstable[3]      table.insert(buffer, '"","","' .. object.name .. '","' .. addresstable[1] .. '/' .. addresstable[2] .. '/' .. addresstable[3] .. '"')   end end --Create attachment inside FTP server src = 'Object export created on ' .. os.date('%Y-%m-%d %H_%M_%S') .. '.csv' dst = '/home/ftp/' .. src io.writefile(dst, buffer) script.disable(_SCRIPTNAME)
For Gmail you might need to enabled "less secure apps" for sending. Also try settings secure = 'tlsv1_2' instead of sslv23. You can also create a separate password for Gmail, see this guide: https://www.lifewire.com/get-a-password-...-2-1171882
(24.07.2019, 16:34)Daniel. Wrote: You can use this script. It will save csv in to ftp main folder
Thank you very much Daniel!!!! It works properly!
(25.07.2019, 06:16)admin Wrote: For Gmail you might need to enabled "less secure apps" for sending. Also try settings secure = 'tlsv1_2' instead of sslv23. You can also create a separate password for Gmail, see this guide: https://www.lifewire.com/get-a-password-...-2-1171882
Dear Edwar,
I tried it quickly because the ftp way works and i have the CSV files downloaded yet. But i want to fix the email to send mails properly but i will deal with it later.
Thank you mate!! Cool
