Mosaic 2.0 what's new
Hello!
You are often doing Mosaic 2.0 update. Sometimes not possible to recognize, what was changed.
Where to see changes/what's new information of each update?
Reminder!
(28.12.2017, 19:20)GenaV Wrote: Reminder!
In did we should post the updates :Smile
We corrected Air Conditioner widget to use correct DPT like for temperature.
There is new Video widget where you can play some web video. It can also be used for IP camera. You can see there 2 URLs one for local and second for remote which will be used in Mosaic Cloud.
We are working on new solution for IP cameras and this will be part of it.
Hi Daniel,
Great to see some updates for mosaic :-)
As for the video widget, what type of url's need to be configured ?
-jpg
-mpeg
-mxpeg (mobotix)
Nicky
(30.12.2017, 22:42)npinguin Wrote: Hi Daniel,
-jpg
-mpeg
-mxpeg (mobotix)
Nicky
We are still limited to what the browser can display. Tested jpeg, mjpeg, mp4. You can try mxpeg and let us know.
Thanks Daniel
I got the following working
Mobotix t25 cam
-http://MYIP/cgi-bin/faststream.jpg?stream=full&fps=0&data=v.mjpg
Axis m1065 Cam
- http://MYIP/axis-cgi/mjpg/video.cgi
But I got a problem with the security:
-need to provide the credentials of each Cam to get it working.
- Unfortunately I cannot provide the username password in the url (http://username:password@url), because then it cannot connect
If I would build a solution, I would recommend
- a dedicated solution integrated in the LM based on FFmpeg
- ability to configure Cam’s and views
- api’s to control the different cam’s and streams/views
- streaming and snapshot mode
have a look at netcamviewer monitor
(31.12.2017, 14:45)npinguin Wrote: Thanks Daniel
Mobotix t25 cam
Axis m1065 Cam
Similar solution we are working on now.
Excellent, mind reading  Smile
In latest version we corrected security widget and now when code is typed the window opens in popup. Due to this buttons are much bigger and easier to press.
Great Daniel, indeed much easier to use
In the co2/humidity/temp widget, it seems that only 1-byte values are accepted, this is a problem as my humidity values are in 2-byte, do i need to convert them with a script myself, or could you add this`?
Dimmer vertical widget statuses does not seem to work`?
Best regards, Jørn.
(30.01.2018, 21:29)Jørn Wrote: In the co2/humidity/temp widget, it seems that only 1-byte values are accepted, this is a problem as my humidity values are in 2-byte, do i need to convert them with a script myself, or could you add this`?
Humidity this is value form 0 to 100% it should be 1byte, please use script to convert.
I will check the vertical dimmer.
Vertical slider works only if it has slightly different behavior as other widgets. The status feedback will be taken in to account only when status object will receive telegram. If you have live device with working feedback then it will work. If you change value and status object will not get telegram then widget will stay in control position. After page refresh the value will go to status value. There is set of widgets which was done by 3rd party and this is one as done by them. I will report this and will wait for the fix.
Thanks, looks like it was just a browser issue ;o)
Best regards, Jørn.
In Today's release version we have new feature which is Widget Creator. Now you can easily build your own widgets in the same way like in custom Visu.
Just try to add new widget and on the bottom there is widget creator.
Very simple, no need to explain anything.
Have fun!
I've updated app but I don't see this editor? What is the path?
Ok. I see that it is on the very bottom in the widget list.
Done is better than perfect
>Widget Creator
Great tool!
Will this also be available for SE SpaceLYnk?
And if so, will it be related to type of HW? As far as I'm informed SE has discontinued FW upgrade for HW v. 1.0
Marius
Where did you got that information?
HW1 will get at least 1 or 2 new versions FW as far as i know...
We are looking to include the widget creator to touch at this moment and for apps you don’t always need new FW so even without new FW apps can be renewed..
(13.05.2018, 10:09)electric24 Wrote: Hi
Marius
Hi, the decision about stopping of releasing FW for hw v1.x.x has not been taken. Firmwares of this old hw are planned in the roadmap for 2018. Information when we will stop releasing of new firmwares for this old hw will be publicated in advance, be sure.
Petr
