Shortcut - iPhone
I am wondering if someone knows a way to create an icon/button on the iPhone screen that directly executes a command on the spacelynk?
For example, a button/icon when pushed on the iPhone turns on the alarm (knx object). This assuming of course that iPhone is connected to the same wifi/local network as the spacelynk...
Mr.D
I would use IFTTT, you can create a widget on the widget screen with IFTTT and then use the maker channel to send a HTTP command to the remote services of the controller.
(05.02.2018, 18:25)Mr.D Wrote: Hi,
You maybe have solved your situation because of the 2 year later answer Tongue  But I have used the Shortcut app in the iphone and used that to make the same http command for the very same purpose.
