19.03.2018, 12:17
Hi to all,
I have to write a single register to a device that only supports Function 16
If I use this it's not working
but if I add another register it'll works
I suspect that the function automatically switches between function 6 and 16 based on the number of registers it has to write.
I know it makes little sense to use MultipleRegister to write a single register but that's the way the device works and I can't change it so I just want to know if is it possibile to "force" function 16 passing only one register.
Thank you
--COMANDO ON/OFF
mb:writeregisters(33822,32)
--COMANDO ON/OFF
mb:writeregisters(33822,32,0)
Thank you
