I think Additional Icons is the feature you are looking for (when adding object in the visualization, there is Additional Icons button on the bottom of plan editor)
You explained it well. What is the problem to put image as object and make it read only. From the display point of view it is the same.
Otherwise some JS will be needed.
I have the drawing of a split and when the user clicks on the widget a widget with full control and if in that widget press the on / off I would like to change the image of the split for another but working.
And I do not know how to do it with an image octopus.
03.05.2018, 08:52 (This post was last modified: 03.05.2018, 08:53 by Erwin van der Zwart.)
It's for a img element and not a object, it's faster to include when having a lot of icons on different values (if you know how) and you can use a remote source for the images. (not possible by additional icons)
