Squeezebox + KNX
Hi, does someone control their squeezbox (logitech media server) using the Logic Machine? I have found that openHAB does do this... maybe there is a direct way of doing this?
There are 2 ways to control it, or by API or by TCP
For API you can use this sample to send HTTP your commands:
require('socket.http')
socket.http.TIMEOUT = 5
ip_logicmachine = '192.168.0.10'
ip_squeezebox = '192.168.0.110'
pause_command = grp.getvalue('1/1/1')
if pause_command == true then
  pause_command = 1
  pause_command = 0
r, c, h, s = socket.http.request('http://' .. ip_squeezebox .. ':9000/status.html?p0=pause&p1=' .. pause_command .. '&player=' .. ip_logicmachine .. '')
if not r then
  log('No reply')
  return
  log®
  --do other actions with reply if needed
On this page are the HTTP / API commands for squeezebox explained:
http://tutoriels.domotique-store.fr/cont...-squeezebox-server-_-player-http.html
For TCP you can use this tcp/ip sample to send tcp/ip commands:
-- TCP/Telnet
local host, port = "192.168.2.60", 23
local socket = require("socket")
local tcp = assert(socket.tcp())
tcp:connect(host, port)
tcpConfusedettimeout(0.5)
-- Send command as HEX
--command = string.char(0xfe, 0xff, 0xff,) -- You need to put here your correct HEX command
-- Send command as STRING
command = ''PUT_HERE_YOUR_COMMAND"
tcpConfusedend(command .. '\r')
--Get replies from controller
local s, status, partial = tcp:receive()
--Check if reply has a value
if s then
  -- Decode data from HEX if needed
  --decodeddata = lmcore.hextostr(s, string.len(s))
  --log(decodeddata)
  --Do your action(s) with replies
  if s == 'put here your expected reply' then
    -- Do actions
if status then
-- log(status)
if partial then
  -- log(partial)
tcp:close()
On this page are the tcp/ip commands for squeezebox explained:
https://crestron-squeeze.googlecode.com/...pi_7.6.htm
Explore those 2 and you can control your device (:
Erwin van der Zwart
Thanks Erwin!
here a short function to send commands to your squeezebox players. I have added them to a user library.
--Functions for Logitech Media Server integration
squeezboxserverip = '192.168.0.XX' -- IP of the Logitech Media Server
function squeezeboxsendcommand(player,command)
 socket=require('socket')
  local client = socket.connect(squeezboxserverip, 9090)
 client:send(player .. ' ' .. command .. '\n')
  local result=client:receive()
  log(result)
  client:close()
and this is an example for an object turning on or off the player
require('user.squeezebox')
onoff = event.getvalue() and 1 or 0
squeezeboxsendcommand('b8:27:eb:ad:6b:c2', 'power ' .. onoff)
