I have a very high cpu load on customer Spacelynk. The Spacelynk wasn't installed by me, but I think it is very strange ! I tried to do a Factory reset without difference ! Do you have Idea ? I also upgrade to 2.1.1 firmware without any difference !
There is no script.. If I put the backup on my test Spacelynk th load is 0,1%
What is fun, is that when rebooting, it start from 0.5 then it's growing in the 3 min to more than 1
CPU/IO: 1.52 0.96 0.54, Memory: 11%, KNX/TP: OK
Memory looks good:
Total system memory
122.7M
Used
13.0M (11%)
Free
109.6M (89%)
Buffered
1.2M
Cached
16.1M
system log
cat /proc/meminfo
Could it be the number of device connected ? There is 4 Touch HP computer I think !
Memory looks good:
Total system memory
122.7M
Used
13.0M (11%)
Free
109.6M (89%)
Buffered
1.2M
Cached
16.1M
system log
May 28 08:34:25 spaceLYnk user.info sysinit: Generating selfsigned certificate with subject 'CN=spaceLYnk;' and validity 2018-05-28 08:34:00-2033-05-18 03:33:20
May 28 08:34:00 spaceLYnk user.info sysinit: Generating RSA private key, 2048 bit long modulus
May 28 08:33:59 spaceLYnk user.info sysinit: Generating selfsigned certificate with subject 'CN=spaceLYnk;' and validity 2018-05-28 08:33:22-2033-05-18 03:33:20
May 28 08:33:30 spaceLYnk kern.notice kernel: [ 25.621675] random: nonblocking pool is initialized
May 28 08:33:22 spaceLYnk user.info sysinit: Generating RSA private key, 2048 bit long modulus
May 28 08:33:19 spaceLYnk user.info sysinit: Configuring touch.
May 28 08:33:19 spaceLYnk user.info sysinit: Configuring fbeditor20.
May 28 08:33:14 spaceLYnk user.info sysinit: Installing touch (20170810) to root...
May 28 08:33:12 spaceLYnk user.info sysinit: Installing fbeditor20 (20170810) to root...
May 28 08:33:11 spaceLYnk kern.info kernel: [ 6.443255] fec 800f0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
May 28 08:33:09 spaceLYnk user.info sysinit: uci: Entry not found
May 28 08:33:09 spaceLYnk kern.info kernel: [ 4.749319] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc
May 28 08:33:09 spaceLYnk user.info sysinit: /dev/mmcblk0p3: clean, 14/131072 files, 25391/524288 blocks
May 28 08:33:09 spaceLYnk user.info sysinit: e2fsck 1.43.7 (16-Oct-2017)
May 28 08:33:09 spaceLYnk kern.info kernel: [ 4.447035] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.ethernet-1:00, irq=-1)
May 28 08:33:07 spaceLYnk kern.info kernel: [ 3.178512] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.ethernet-1:00, irq=-1)
May 28 08:33:07 spaceLYnk kern.info kernel: [ 2.833436] watchdog timeout 60 seconds
May 28 08:33:07 spaceLYnk kern.info kernel: [ 1.698404] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc
May 28 08:33:07 spaceLYnk kern.info kernel: [ 0.898524] Freeing unused kernel memory: 140K
May 28 08:33:07 spaceLYnk kern.info kernel: [ 0.897745] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
May 28 08:33:07 spaceLYnk kern.info kernel: [ 0.897569] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
May 28 08:33:07 spaceLYnk kern.info kernel: [ 0.767230] mmcblk0: p1 p2 p3
May 28 08:33:07 spaceLYnk kern.info kernel: [ 0.764655] mmcblk0: mmc0:59b4 00000 3.67 GiB
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.762780] mmc0: new high speed SDHC card at address 59b4
May 28 08:33:06 spaceLYnk kern.warn kernel: [ 0.760229] mmc0: host does not support reading read-only switch, assuming write-enable
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.753740] Waiting for root device /dev/mmcblk0p2...
May 28 08:33:06 spaceLYnk kern.err kernel: [ 0.753577] Warning: unable to open an initial console.
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.751642] rtc-ds1307 0-006f: setting system clock to 2018-05-28 08:33:05 UTC (1527496385)
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.745389] NET: Registered protocol family 17
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.722434] mxs-mmc 80010000.ssp: initialized
May 28 08:33:06 spaceLYnk kern.warn kernel: [ 0.690655] 80010000.ssp supply vmmc not found, using dummy regulator
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.689497] usbcore: registered new interface driver btusb
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.683981] lirc_dev: IR Remote Control driver registered, major 248
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.682643] i2c /dev entries driver
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.681180] rtc-ds1307 0-006f: 64 bytes nvram
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.681059] rtc-ds1307 0-006f: rtc core: registered mcp7941x as rtc0
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.677569] g_ether gadget: g_ether ready
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.677256] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
May 28 08:33:06 spaceLYnk kern.warn kernel: [ 0.677002] using random host ethernet address
May 28 08:33:06 spaceLYnk kern.warn kernel: [ 0.676925] using random self ethernet address
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.676753] usb0: MAC c6:ee:90:93:67:f8
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.676444] usb0: HOST MAC 46:bb:37:f9:92:13
May 28 08:33:06 spaceLYnk kern.warn kernel: [ 0.673143] using random host ethernet address
May 28 08:33:06 spaceLYnk kern.warn kernel: [ 0.673053] using random self ethernet address
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.670904] hub 1-0:1.0: 1 port detected
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.670668] hub 1-0:1.0: USB hub found
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.668520] usb usb1: SerialNumber: ci_hdrc.0
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.668490] usb usb1: Manufacturer: Linux 4.4.109 ehci_hcd
May 28 08:33:06 spaceLYnk kern.info kernel: [ 0.668459] usb usb1: Product: EHCI Host Controller
* table:
[1]
* string: MemTotal: 125624 kB
[2]
* string: MemFree: 93332 kB
[3]
* string: MemAvailable: 108536 kB
[4]
* string: Buffers: 1340 kB
[5]
* string: Cached: 16880 kB
[6]
* string: SwapCached: 0 kB
[7]
* string: Active: 19408 kB
[8]
* string: Inactive: 4400 kB
[9]
* string: Active(anon): 5820 kB
[10]
* string: Inactive(anon): 68 kB
[11]
* string: Active(file): 13588 kB
[12]
* string: Inactive(file): 4332 kB
[13]
* string: Unevictable: 0 kB
[14]
* string: Mlocked: 0 kB
[15]
* string: SwapTotal: 0 kB
[16]
* string: SwapFree: 0 kB
[17]
* string: Dirty: 16 kB
[18]
* string: Writeback: 0 kB
[19]
* string: AnonPages: 5596 kB
[20]
* string: Mapped: 3660 kB
[21]
* string: Shmem: 308 kB
[22]
* string: Slab: 4628 kB
[23]
* string: SReclaimable: 1640 kB
[24]
* string: SUnreclaim: 2988 kB
[25]
* string: KernelStack: 352 kB
[26]
* string: PageTables: 248 kB
[27]
* string: NFS_Unstable: 0 kB
[28]
* string: Bounce: 0 kB
[29]
* string: WritebackTmp: 0 kB
[30]
* string: CommitLimit: 62812 kB
[31]
* string: Committed_AS: 9496 kB
[32]
* string: VmallocTotal: 901120 kB
[33]
* string: VmallocUsed: 0 kB
[34]
* string: VmallocChunk: 0 kB
SE ECO EXPERT
SE ECO EXPERT
