I know there's a limit on COV subscriptons on the LM4, but the way I see there should be no problem using event scripts to send to a foreign bacnet device as a poor mans COV subscription?
There will be about 200 scripts that will send on change (event). Will this be a problem or do you think the LM4 is capable of handling this traffic?
Since the default COV value is 1 and cant be changed easily from LM4 we will try to just use event based sendings on the values.
Will limit the sendings on the KNX devices so the traffic is at a minimum.
But for binary values a COV of 1 is sufficient and we see that about 50 COV subscriptions will fit most projects we have.
If CO2 deviced are used there will be need of about 100 COV values so in general a limit of 100 will be enough for most use-cases.
