App to display object info
Hello my goal is to make a app to display battery info for all my battery powered devices.
Tags used in the object: battery_chk1 (20 devices) and battery_chk2 (10 devices).
How to make a app that displays the object name, object value, last updated time (order by tag, object name)?
<? require('apps') d1 = grp.tag('battery_chk1') d2 = grp.tag('battery_chk2') ?> <!DOCTYPE html> <html> <head> <meta charset="UTF-8"> <title>Objects</title> <link rel="stylesheet" href="/apps/css/bootstrap.css"> <link rel="stylesheet" href="/apps/css/font-awesome.css"> <link rel="stylesheet" href="/apps/css/style.css"> <script src="/apps/js/jquery.js.gz"></script> <style> body { padding: 20px; background-color: #fff; } .navbar { background-color: #eee; } </style> </head> <body> <div class="navbar navbar-default navbar-fixed-top"> <div class="container-fluid text-center"> <span class="btn btn-default navbar-btn pull-right back"><span class="fa fa-lg fa-times"></span></span> <span class="btn btn-default navbar-btn pull-left refresh"><span class="fa fa-lg fa-refresh"></span></span> <span class="navbar-brand">Objects</span> </div> </div> <div class="wrap"> <div class="container">   <table class="table table-hover">     <thead>       <tr>         <th>Name</th>         <th>Value</th>         <th>Date</th>       </tr>     </thead>     <tbody></tbody>   </table> </div> </div> <script> $(function() {   function render(data) {     // sort data by name     data.sort(function(a, b) {       var na = a.name.toLowerCase()         , nb = b.name.toLowerCase();       if (na > nb) {         return 1;       }       else if (na < nb) {         return -1;       }       else {         return 0;       }     });     // show each object name/value/update time     $.each(data, function(index, item) {       var trs = $('<tr><td></td><td></td><td></td></tr>').appendTo('tbody')         , tds = trs.find('td')         , d = new Date(item.updatetime * 1000);       $(tds[ 0 ]).text(item.name);       $(tds[ 1 ]).text(item.value);       $(tds[ 2 ]).text(d.toString().split(' GMT')[0]);     });   }   render(<?=json.encode(d1)?>);   render(<?=json.encode(d2)?>);   $('.refresh').click(function() {     window.location.reload();   });   $('.back').click(function() {     $(this).find('.fa')       .removeClass('fa-times')       .addClass('fa-refresh fa-spin')     window.location = '/apps/';   }); }); </script> </body> </html>
thnks....
It gives: Uncaught SyntaxError: Unexpected token < at:
Which firmware version are you running?
Try this:
render(<? write(json.encode(d1)) ?>); render(<? write(json.encode(d2)) ?>);
(10.10.2017, 06:11)admin Wrote: Which firmware version are you running?
Try this:
Versie: 20170620
same error:
Are you putting this into .lp file? It must be .lp, .html will not work.
(10.10.2017, 06:26)admin Wrote: Are you putting this into .lp file? It must be .lp, .html will not work.
yes, that works.. Thanks
