email setting
our smtp server needs to enable tls. what is the right parameter for secure?
txs
Put tlsv12 there, but in most cases port 587 uses STARTTLS mode, so you need to install updated LuaSocket package. Which hardware are you using?
(10.10.2017, 12:24)admin Wrote: Put tlsv12 there, but in most cases port 587 uses STARTTLS mode, so you need to install updated LuaSocket package. Which hardware are you using?
I have 1 LM4
and 1 LM5
with last firmware and with luashocket 2.0.2-17 both.
My smtp server setting are
So do i need to install LuaSocket package?
Update package from System config-> System > Packages > Click (+) icon
Package for LM4:
http://dl.openrb.com/lm-17/pkg/luasocket...23_mxs.ipk
Package for LM5:
http://dl.openrb.com/lm-17-imx6/pkg/luas...3_imx6.ipk
First try with secure = 'starttls',
If it does not work then try secure = 'tlsv12',
In your script put mail function call inside log( ) so you can see an error message in logs if there is any.
(11.10.2017, 07:59)admin Wrote: Update package from System config-> System > Packages > Click (+) icon
Package for LM4:
http://dl.openrb.com/lm-17/pkg/luasocket...22_mxs.ipk
Package for LM5:
http://dl.openrb.com/lm-17-imx6/pkg/luas...2_imx6.ipk
hi
with secure = 'starttls' email() returns
* arg: 1
 * nil
* arg: 2
 * nil
 and with secure = 'tlsv12'
* arg: 1
 * nil
* arg: 2
 * string: closed
Can you send login/password that your are using via PM so I can check it locally?
(11.10.2017, 10:27)admin Wrote: Can you send login/password that your are using via PM so I can check it locally?
sent it
Thanks, please update packages again:
Package for LM4:
Package for LM5:
Replace mail() function in Common functions with this and change from/user/password field values to your access details:
  local settings = {
    from = '...',
    -- smtp username
    user = '...',
    -- smtp password
    password = '...',
    -- smtp server
    server = 'mailgate.cosmotemail.gr',
    -- smtp server port
    port = 587,
    -- enable tls
    secure = 'tlsv1',
    -- use STARTTLS mode
    starttls = true,
  if type(to) ~= 'table' then
    to = { to }
  for index, email in ipairs(to) do
    to[ index ] = '<' .. tostring(email) .. '>'
  -- fixup from field
  local from = '<' .. tostring(settings.from) .. '>'
  -- message headers and body
    headers = {
      to = table.concat(to, ', '),
      subject = subject,
      ['From'] = from,
      ['Content-type'] = 'text/html; charset=utf-8',
    body = message
  settings.from = from
  settings.rcpt = to
  return smtp.send(settings)
(13.10.2017, 08:45)admin Wrote: Thanks, please update packages again:
Package for LM4:
Package for LM5:
 local settings = {
   from = '...',
   -- smtp username
   user = '...',
   -- smtp password
   password = '...',
   -- smtp server
   -- smtp server port
   port = 587,
   -- enable tls
   secure = 'tlsv1',
   starttls = true,
   to = { to }
 -- fixup from field
   headers = {
     subject = subject,
     ['From'] = from,
   body = message
 settings.rcpt = to
it works perfect. Thank you very much
Can you send me the package for LogicMachine5 Lite Power?
It's already there:
