28.10.2017, 05:34
How to turn on the mono sound in Amati.linea? I can't find this function, is it possible?
Mono sound
28.10.2017, 05:34
31.10.2017, 09:44
Do you want to output to only one speaker? This is only possible on streaming player without amplifier. Here's some info on how to do line-level stereo to mono conversion: http://www.rane.com/note109.html
04.11.2017, 11:35
(31.10.2017, 09:44)admin Wrote: Do you want to output to only one speaker? This is only possible on streaming player without amplifier. Here's some info on how to do line-level stereo to mono conversion: http://www.rane.com/note109.html No, I have two speakers in different rooms, so I want to hear all of music in one room. There are many stereo recorded music, and e.x. 5 second of music is on the left side, another 5 second is on the right, so in one room I can hear nothing this 5 second.
13.03.2018, 10:37
I have the same problem. We have many installations with only one speaker per room and need to send sound as mono. I'm using a streaming player with amplifier for tests. I will try the solution in rane.com but it isn't the ideal solution. @admin says its possible on streaming player without amplifier. How is it possible exactly? Is there a option on software? I can't find any information about this in the manual. Thank you in advance. BR, Neves
13.03.2018, 11:23
Do not use the solution I've posted for player with built-in amp, you can damage it that way.
Mono is possible to implement in software though it has not been tested yet and there's no UI option for this.
13.03.2018, 12:44
Ok.
![]() Mono is a very important feature for us and I think it's to other users too. Do you have an estimate for when it would be available? BR, Neves
15.03.2018, 14:45
Try this image:
https://dl.openrb.com/audio/imx28-20180313.img Note that mono will not work for external sources (spdif/toslink), if your device has them.
29.05.2018, 09:44
Hi Admin,
Thank you. It worked. BR, A Neves |
« Next Oldest | Next Newest »
