Mono sound
How to turn on the mono sound in Amati.linea? I can't find this function, is it possible?
Do you want to output to only one speaker? This is only possible on streaming player without amplifier. Here's some info on how to do line-level stereo to mono conversion: http://www.rane.com/note109.html
(31.10.2017, 09:44)admin Wrote: Do you want to output to only one speaker? This is only possible on streaming player without amplifier. Here's some info on how to do line-level stereo to mono conversion: http://www.rane.com/note109.html
No, I have two speakers in different rooms, so I want to hear all of music in one room. There are many stereo recorded music, and e.x. 5 second of music is on the left side, another 5 second is on the right, so in one room I can hear nothing this 5 second.
I have the same problem. We have many installations with only one speaker per room and need to send sound as mono.
I'm using a streaming player with amplifier for tests. I will try the solution in rane.com but it isn't the ideal solution.
@admin says its possible on streaming player without amplifier. How is it possible exactly? Is there a option on software? I can't find any information about this in the manual.
Thank you in advance.
Neves
Do not use the solution I've posted for player with built-in amp, you can damage it that way.
Mono is possible to implement in software though it has not been tested yet and there's no UI option for this.
Ok. Smile
Mono is a very important feature for us and I think it's to other users too.
Do you have an estimate for when it would be available?
Neves
Try this image:
http://dl.openrb.com/audio/imx28-20180313.img
Note that mono will not work for external sources (spdif/toslink), if your device has them.
Hi Admin,
Thank you. It worked.
A Neves
