spaceLYnk Hw Version?
#21
Ah, ok, thank you. It is a 3 then.
Is there a way to get this info with a script, in addition to FW version and CPU load?
Try this:
local ARM = io.readproc('cat /proc/cpuinfo | grep \"model name\"'):match('%d+')
log(ARM)
local FW = io.readfile('/lib/genohm-scada/version'):split('.')
FW = FW[1]*1000000 + FW[2]*1000 + FW[3]
log(FW)
(10.03.2019, 00:07)Erwin van der Zwart Wrote: Hi,
Try this:
log(ARM)
log(FW)
Great, thats what I need. Thank you!
Hi Erwin,
is possible to use your script with latest LM? I just tried to start it, and receive back this:
FW * string: 7
and error log:
Resident script:6: attempt to perform arithmetic on a nil value
stack traceback:
Yes should work but i think i try to multiply a string value in line 6.
Change FW[1] to tonumber(FW[1]) and do the same with 2 and 3.
Or remove line 6 to get the FW as RAW string, we needed it to BACnet
and the controller does not support BACnet string values so that is why
we convert it to a analog value like 2003001. In this case it’s FW 2.3.1
LM version is already a number in YYYYMMDD format, so split is not needed.
In that case you can use:
log(FW)
thank you for answers, FW now shoved correctly, but this code below no any log at all.. May be it depends of CPU type?
log(ARM)
cpu = io.readfile('/proc/cpuinfo'):match('model name%s+:%s+([^%s]+)')
log(cpu)
