30.10.2017, 00:52
Hello all,
I'm pretty new to the LM5, but by now have already spent a couple of days with the device and we are getting there.
However, I can't seem to get my DALI setup working and I can't figure out what is wrong, as it should be relatively easy.
- I'm using a LUNATONE DALI PS
- Connected to my LM5
- Connected to one DALI Ballast (EldoLED PowerDrive)
Electrically, everything should be ok (seperate DALI power supply, all 3 devices connected in parallel: power supply, ballast, LM5).
But how many times I try, when scanning, nothing is found (I tried another power supply of the same make, I tried both ports on my LM5, etc.)
A strange behaviour is however that when I reset my DALI ballast, it says no address set (it has a display="ADDR NO"), but after I ran the bus scan from LM5, it says that an address has been set ("ADDR SET"), so something is happening.
Another thing strange thing is that my user.dali script/library is empty? Is this normal?
Running an LM5p-RD with version 20170620.
