a better KODI handler
How to make a handler that interacts with KODI.
Data can be send to kodi on port 9090 (or another port you configured) using a raw connection with putty.
My goal:
- send command to kodi, for example i can send this command: { "jsonrpc": "2.0", "id": 1, "method": "Application.SetVolume", "params": { "volume": 53 } }
- receive executed events from kodi, for example i receive this command: {"jsonrpc":"2.0","method":"GUI.OnScreensaverDeactivated","params":{"data":{"shuttingdown":false},"sender":"xbmc"}}
- receive commands from my lm/hl over udp and send them to kodi
I like to have this all in one handler. I have already a piece of code that works, but its to slow. It waits on udp command and that interrups my receiving events.
Maybe using copas or something solved the issue, but how? Smile
kodiHandler("192.168.x.x","9090","12007")
-- library
function kodiHandler(iServer,iPort,sendPort)
 -- first call
 if not ready then
   require('socket')
   require('json')
   lastdatareceived = nil
   ready = true
 -- client connected
 if connected then
   while true do
     char, err = client:receive(1)
     -- error while receiving, closed socket
     if err == 'closed' then
         connected = false
       sleep(1)
       break
     if char ~= nil then
       lastdatareceived = os.time()
       warningclosed = true
       warningfailed = true
       warningerrors = true
       warningtimeou = true
                table.insert(buffer, char)
       tmpbuf = table.concat(buffer)
       if ( json.pdecode(tmpbuf) ) then
         data = tmpbuf
         parse(data)
         buffer = {}
       now = os.time()
       deltatime = now - lastdatareceived
     -- receive incoming send requests
         msg, ip, port = sendServer:receivefrom()
            if msg then
       -- send command
       --log("send: "..msg)
       client:send(msg)
     --[[ clear not complete buffer
     if deltatime > 10 and #buffer > 0 then
       log( #buffer )
       buffer = {}
   -- first call or previously disconnected
   -- close previous connection when disconnected
   if client then
     client:close()
     client = nil
   if sendServer then
     sendServer:close()
     sendServer = nil
   -- create tcp client
   client = socket.tcp()
   client:settimeout(5)
   connected, err = client:connect(iServer, iPort)
   -- connect ok, reset buffer
   if connected then
     --log('[KODI-client] connection ok: '..iServer)
     buffer = {}
     -- create udp server to receive incoming send requests
            if not sendServer then
              sendServer = socket.udp()
              sendServer:setsockname('*', sendPort)
              sendServer:settimeout(0.1)
     sleep(5)
     -- send initial command
     --client:send( '{"jsonrpc": "2.0", "method": "Player.PlayPause", "params": { "playerid": 0 }, "id": 1}' )
     -- error while connecting,
            --log(err)
     if warningfailed then log('[KODI-client] connection failed (conn): '.. err) end
     warningfailed = false
     sleep(5)
 -- incoming command parser
 function parse(data)
   -- log other info, not mapped, if useful
   --log("data received: "..data)
   --log(json.pdecode(data))
Use this as a starting point, it uses non-blocking socket.select() so UDP won't interfere. The only blocking part is TCP re-connection. There's no need to close/open local UDP server each time.
if not sockets then
  require('socket')
  clientip = '192.168.1.xx'
  clientport = 9090
  serverport = 12007
  udpserver = socket.udp()
  udpserver:setsockname('127.0.0.1', serverport)
  udpserver:settimeout(0)
  sockets = { udpserver }
  function tcpconnect()
    local tcpclient = socket.tcp()
    tcpclient:settimeout(1)
    if tcpclient:connect(clientip, clientport) then
      tcpclient:settimeout(0)
      tcpclient:close()
      tcpclient = nil
      os.sleep(1)
    return tcpclient
  function reconnect()
    repeat
      tcpclient = tcpconnect()
    until tcpclient
    sockets[ 2 ] = tcpclient
  function errhandler()
    tcpclient:close()
    reconnect()
  function clienthandler()
    while true do
      local char, err = tcpclient:receive(1)
      if char then
          errhandler()
        break
  function serverhandler()
    local msg = udpserver:receive()
    if tcpclient then
      tcpclient:send(msg)
  reconnect()
res = socket.select(sockets, nil, 1)
if res then
  if res[ tcpclient ] then
    clienthandler()
  if res[ udpserver ] then
    serverhandler()
yes, that works great!
Hi did you manage to have a feedback from Kodi ? for instance having a feedback when the film is finished to open the shutters and tun on the light etc ... ?
thanks
(02.05.2019, 07:53)gilles38 Wrote: Hi did you manage to have a feedback from Kodi ? for instance having a feedback when the film is finished to open the shutters and tun on the light etc ... ?
thanks
edit this code and call a function in the main script:
thanks
thanks Wink
I finally add an addon to Kodi called "callback" that allow you to launch script on a specific action in Kodi.
in my case it update a group address Smile
