I'm newbie and probably will ask dum questions but ...
Need to make failure visualization and warning on a project with 85 emergency ECGs connected to DALI and HL for wrong searching ECGs and battery change need.
Any suggestions, recommendations or guide lines?
Will touch visualization be the easiest?
Will the HL DALI app help?
How about alerts and logs?
The DALI app does not show any ECGs og Groups no matter that I imported ESF file from ETS and object are shown. What did I miss?
Is there any manual for these apps online?
Sorry for this but: what is GW?
06.12.2017, 09:27 (This post was last modified: 06.12.2017, 09:27 by Erwin van der Zwart.)
What brand DALI gateway (GW) do you use? If you use our MTN6725-0001 then you can connect it to IP and add the used IP address in the DALI app, then you can see all info from the GW. The DALI app doesn't use any ETS information. The app does not work on other brand GW's
06.12.2017, 09:44 (This post was last modified: 06.12.2017, 13:45 by Mrinj.)
I use MTN6725-0001 with IP, accessible and configured with ECGs and Groups via browser. The app finds the GW, name and IP, but there are no ECGs or DALI Groups present in the app.
I solved the problem and ECGs are shown in the DALI app now. Thank you!
Erwin, you say: "The GW has error object that you can use to trigger alert manager and there you can notify to check the DALI app for detailed information."
Do I need to create an Alert script that will be active in the Alert App notifying when errors at the DALI ECGs?
Does the Alert app send email or other modifications? How does the Alert app notify the user or programmer?
Did some more testing, reading and forum search. Made scripts for email warning and alerts as Erwin described. Great Apps!!!
Thank you Erwin for your support! Thank you all for at this place exists!
Create a scheduled script on the 1th of the month and attach this script to it, you will automatically get a report of the burning hours, failures, etc once a month.
We have a project in Brussels (Gare Maritime) where we are using 109 Dali gateways from Schneider (MTN6725-0001, 0003, 0004).
There are 11 buildings with 4 floors each and we have a Spacelynk per building.
The maintenance company asked us if it's possible to check all Dali GWs for errors and send them a report by mail every two weeks.
According to the manual (see attachement), we have made available object 20/22 1byte central diagnostics value 238.600 per Dali channel.
Since my lua skills very basic, could you help me implement this function in a sophisticated way?
238.600 1 byte DALI diagnostics data type is supported out of the box. In scripts you will get the diagnostics value as a table with 3 fields: address (number), ballasterror (bool) and lamperror (bool)
(05.03.2024, 10:50)admin Wrote: 238.600 1 byte DALI diagnostics data type is supported out of the box. In scripts you will get the diagnostics value as a table with 3 fields: address (number), ballasterror (bool) and lamperror (bool)
-- get object logs
query = [[
SELECT ol.*, o.name, o.datatype
FROM objectlog ol
LEFT JOIN objects o ON ol.address=o.id
WHERE logtime >= ?
ORDER BY id DESC
function fmtdpt(dpt)
if dpt >= 1000 then
dpt = string.format('%0.3f', dpt / 1000)
return dpt
for _, row in ipairs(db:getall(query, logtime)) do
id = tonumber(row.address) or 0
ia = tonumber(row.src) or 0
if (etype == 'write' or etype == 'response') and row.datatype then
textdpt = fmtdpt(row.datatype)
value = grp.decodevalue(row.datahex, row.datatype)
value = ''
buffer[ #buffer + 1 ] = string.format('%q,%q,%q,%q,%q,%q,%q,%q,%q',
logdate,
etype,
buslib.decodega(id),
row.name or '',
tostring(textdpt or ''),
tostring(value),
ia > 0 and buslib.decodeia(ia) or 'local',
row.sender or '',
row.meta or ''
if #buffer > 1 then
data = table.concat(buffer, '\r\n')
io.writefile(ftpfile, data)
Since we log other objects also can we implement this but only for Tagged with 'Dali Error' objects?
P.S. Is there a known issue with email notifications subscription on threads? It seems that I cannot get emails for the last month or so.
1. Place the function definition after require('socket.ftp')
2. Replace this line:
With these:
if row.datatype == dt.dalidiag then
value = busdatatype.decode(row.datahex, row.datatype)
value = dalidiagtostring(value)
Thanks for letting us know, we will take a look into email notifications issue.
When I look into the object value of 238.600 1 byte DALI diagnostics data type, I see that the address starts from 0 but the numbering in the Dali gateway and then on the as built plans starts from 1. I know this is a detail but is there an easy way to visually overcome this issue? It's because once the logs are exported to the CSV file, the maintenance person has to remember to add +1 on each device showing error to point out the correct light in the end.
