Threads: 31
Hi, I have a question about a iem3155 Energy Meter and LM5, I need to make a trend with a kwh in a hour period and the meter only give me a total kwh that it read, I try to make a script that subtract the two values readed in one hour period, Can you help me to make this script? Exist another possibility yo make this? Thank you very much!
Threads: 8
20.12.2017, 19:31
(This post was last modified: 20.12.2017, 19:31 by Erwin van der Zwart.)
Create a trend with type "counter" for this and set the trend resolution to 1 hour..
Threads: 8
That’s exactly what a counter trend does, just try one then you see what i mean.
It only shows the (calculated) power used (difference) in every hour.
You can extract this hour usage data with trend.fetch when you want to report something.
Threads: 18
12.01.2018, 16:58
(This post was last modified: 12.01.2018, 19:33 by Mr.D.)
Is there a way to have the trend resolution larger than 1 hour, like 24 hours or even weekly/monthly?
Mr.D
Threads: 31
(12.01.2018, 16:58)Mr. Danielsen Wrote: Hi,
Mr.D
Just look on the Trend app and you will see it on right side. All this is there out of the box.
