Failure in the actions from visualization
Hello!
I've got a problem with visualization and the switch actuation. The problem is that, when I'm on the editor screen buttons works fine, but when I open the visualization page (/scada-vis) I can only switch once and then I need to refresh the webpage to be able to switch again the button. The fact is that last week it was working fine and suddenly today the problem appeared. What can I do with that?
Thank you
David
(15.01.2018, 13:57)David Wrote: Hello!
Thank you
David
Let me guess. You use HL or SL? If this is true then just update firmware to latest version. There was a bug which was fixed.  Make sure you clear browser cache after upgrade.
